Wanted: Short Tiger Shifter Made for Hurst
Mlerne
David Kee no longer makes them. Just in case someone has an extra laying around. Thanks, Michael
I never heard back from you re: David Kee 'borrowing my shifter' for a pattern to make more. You'd mentioned he might make more with a sample.. Did you get back to him on that ??
I have a good 'extra' oil pressure gauge BTW.. email me through the forum
To resurrect an old thread, I am looking for one too with the Hurst 2 bolt bottom pattern.
Application is to fit a T5 transmission, so the reverse lockout tabs can be for show only
Looks good but not Hurst quality - IE not a 1 piece forged unit, and no serrations where it bolts to the shifter base.
Then again I probably will not beat on it hard enough to make a difference and might have no choice if nothing better
I am leaning towards a Core shifter base that will accept any Hurst stick. I am leaning towards the Hurst 7238 stick:
https://core-shifters.com/collections/hurst-sticks/products/hurst-chrome-super-shifter-stick-7-5-7238-camaro-firebird-1957-1967-corvette
https://core-shifters.com/pages/swap-bases
TAH_Tiger
Hurst
Here are pics of the spare Hurst 7238 that I have.
Sorry, when you mentioned the lock out, I had thought you wanted a stock looking Tiger shifter that had a hurst bolt pattern.
I do and appreciate your lead. If it was a single piece design, and ideally with serrations to match the Hurst/Core shifter base I would buy it
Failing that I will have to settle for the Hurst stick, or convince myself that the repro is suitable
I am doing a T5 transmission conversion using the AMC tailshaft housing, which requires a shifter base for the 4 bolt AMC/S10 pattern, rather than the new short throw Ford one on the T5 I bought
A while ago i saw a T peice that had the hurst 2 hole vertical pattern with seration and a hirizontal fave to mount a stock shifter, i thought this was a good solution.
I have the top loader with a hurst short shift linkage and shifter nut want to mount the original long cranked tiger shifter to it as 3rd is a bit of a stretch with the seat all the way back and harness on.
Bryan
I think autokrafters has themhttps://www.autokrafters.com/p-7892-shift-lever-mount-adapter-2-inches.aspx?keyword=7210h689
I have what appears to be the exact same shifter...bought it from Dan Williams ( for my Hurst comp plus linkage ) about 10 years ago and it was listed as a '289 Cobra repro' ( US$200 back then with no knob! ). The 'T' moves up and down and no serrations at the base but after you tighten up those 2 - 3/8" bolts I never had a problem there. The Mustang guys sell a T5 pattern knob that looks like the top loader one ...
I used a Hurst knob which I find fits my hand a lot better and made my own stick out of a piece of 7/8" s.s. when I installed the T5/AMC ... trans was mounted 5° to the left as in a stock Mustang
Jim is helping me with the T5 conversion................
