Ford 302 timing cover??
Tweak
I'm working on a parts list necessary to replace my 260 with an older block 302. The 302 I have has the front sump and front dipstick. It sure looks like the 302 timing cover works, but I thought I would ask the experts here. I'd like to keep the 260 as complete as possible if it's return to the engine bay of the tiger is desired.
Thanks,
PITT40
I would just use the 260 timing cover on the newer 302 and then swap it back to the 260 if you ever reinstall that motor. That's what I did.
The new timing covers have different water pump depths, exit sides, etc and it could get messy trying to get pulleys to line up. Using all of the original Tiger stuff is your best bet.
Tweak
Thanks. Does that mean you would use the 260 harmonic balancer too?
JB66CAT
Harmonic balancer
Going through the same checklist. Found this chart:
Small-Block Ford Imbalance Specs
Engine U.S. Model Years Imbalance
221 1962–1963 28.2 oz-in
255 1979–1982 50 oz-in
260 1962–1964 28.2 oz-in
289 1963–1968 28.2 oz-in
302 1968–1980 28.2 oz-in
Boss 302 1969-1970 28.2 oz-in
302 1981–2001 50 oz-in
351W (Windsor) 1969–1997 28.2 oz-in
351C (Cleveland) 1970–1974 28.2 oz-in
