Battery cable pass thru
I have read the threads about routing the battery cable from the battery to the starter solenoid. My problem is wher is the hole in the firewall that the cable passes thru. I am thinking my body man may have welded it up. There is no hole. Can anyone assist ?:eek:
Mine comes through here...
Thank you, I found the hole. Not easy when the Tiger is midnight blue and in a shed. There is also soundproof sheeting on the inside covering the hole.:eek:
