Hi all, I bought a mk1a a while ago and the previous owner welded 6" x 6" steel plates on the top face of the truck floor above the exhaust hangers.
It is poor quality welding and a lot of it so the easiest solution would be to just cut these areas out and weld in trunk sheet metal.
If anyone out there has any trunk material let me know.
I'm an optimist so I'll add that I also need a partial transmission tunnel.
The flared part over the bellhousing is still there, I need the U shaped section that has the shifter hole.
thanks
thanks
