Go Back   California Association of Sunbeam Tiger Owners Forum > Tiger Technical - Personalized/Modified > Engine
New Threads
Reply
Thread Tools Display Modes
  #1
Old 07-13-2017, 05:54 AM
pappentl pappentl is offline
Bronze Forum Member
Member of C.A.T.
Default replace heated spacer with 4 barrel version?
I've switched to an Edelbrock Performer manifold and will run a 4 barrel carb. What are the advantages/disadvantages of replacing the stock heated spacer with either a 4 barrel heated spacer (http://www.mansfieldmustang.com/03-14.JPG) or a non-heated spacer? TIA.
...tom
B9473100
  #2
Old 07-13-2017, 09:30 AM
mr55s mr55s is offline
Silver Forum Member
Member of C.A.T.
Default Spacer
You might enjoy the benefits of a phenolic spacer, it looks like bakelite plastic and is a good insulator between the intake and the carb. You don't want the heat to transfer to your carburetor, doing so will make fuel "boil or percolate", in some instances in hot weather giving you a car that doesn't run well or at all. A nice spacer you can find on an Ebay search is from a Boss 302 application. It's about 3/8" thick and still provides a tube to plug your pcv valve into, or you can plug it off if you have a different route. If you can't find it, try Summit or one of the Mustang supply business's. One word of caution is the thickness and how much room you have left once the hood is closed, crumple up some tin foil loosely and close your hood before you get a spacer, then you will have some sort of an idea of the room available and thickness of the spacer needed. With so many intakes out there, this is a good exercise to check before you go too far
Just my 2 cents
Brian
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
