Go Back   California Association of Sunbeam Tiger Owners Forum > Tiger Technical - Personalized/Modified > Gearbox (wide ratio, 5 or 6 speed)
New Threads
Reply
Thread Tools Display Modes
  #21
Old 03-13-2017, 08:52 PM
Moondoggie's Avatar
Moondoggie Moondoggie is offline
Platinum Forum Member
Member of C.A.T.
Default
Quote:
Originally Posted by Warren View Post
Dawg get your facts straight. I know the car in question you don't. Some guys build cars their way. The Vendors regardless of participation on CAT are all welcome in the White pages and are free to sell on eBay .
The AC Housing's sell for more on eBay as it enables Sunbeam Specialties and Sunbeam Spares to sell for less than my eBay price, plus we sell for less here on CAT, TEAE and everywhere else that it's allowed.
Doing something right is relative to their taste for their modified vehicle and nothing more. Dale MDL and Bill Martin have nice options for someone who doesn't want to cut their car. When the forum postings are moderated it's almost always at a request of a director, they made the rules I'm just the cop hence my alter ego Lego good cop.
Avatar.
I believe I have my facts correct. In Jim's original post he was very happy with the TKO he has in his street rod and then he posted an add from the company that he bought it from. I merrily informed those that had not read the entire post that a stock TKO would not fit in a tiger without some serious machining and modification supporting the additional price over the stock out of the box TKO price. You took that and made into some drunken sailor deal that was way off base...lego cop or not it stinks
Moondoggie
  #22
Old 03-13-2017, 09:23 PM
Warren's Avatar
Warren Warren is offline
CAT Vendor Manager
Member of C.A.T.
Default Watch out
For the little guy. In the multitude of threads we have on the subject it would be unrealistic to think that even a Nube Tiger owner would blindly click and order a transmission from the first link he sees. We appreciate your attempt to look after the little guy. What you fail to give value to is some guys will be more happy digging and looking for an AMC tail shaft and the satisfaction of doing it themselves.
  #23
Old 03-31-2017, 12:08 AM
JB66CAT's Avatar
JB66CAT JB66CAT is offline
Silver Forum Member
Member of C.A.T.
Default TKO
Quote:
Originally Posted by Moondoggie View Post
Jim,
I'm not sure why you posted the link. So that you know, you can't just buy a generic TKO600 kit and have it bolt right into a Tiger. What MDL does to solve this issue is they machine the tail housing to clear the x member and manufacture and install the components necessary to move the shift handle
over to the side so it fits into the stock trans tunnel hole. So no modifications are required to install unlike the T5 which is turned on it's side requiring the tunnel be expanded with a come along. MDL's kit also includes a new rear mount bracket and driveshaft...
Moondoggie
I have a bad habit of not explaining things enough sometimes. ;-) I posted the link because the price is way lower than what others had posted for the tremec. And, the one I have is not in a Tiger. So, I was just providing a link to the company where I got mine for informational use. All of the extra parts etc. that would be needed to install in a Tiger are obviously going to boost the price. Certainly, it would be wise to go with a supplier that has experience with Tigers. IIRC the tremec has multiple ways to mount the shifter. At any rate I'm sticking with the T5 for now in the Tiger. The TKO600 in my hot rod works like a dream though.
__________________
Jim B382000364
  #24
Old 05-04-2017, 09:29 AM
ModernDriveline ModernDriveline is offline
Supporting Pro Vendor
Member of C.A.T.
Default
This Bruce with Modern Driveline. Just want to chime in and help those with questions.
With Help from Bill Doolittle and Bill Martin I developed the Tiger TKO600 so it would bolt in without modification to these valuable Tigers. I have seen what was done before and come with a better way to install a five speed overdrive shaft transmission that would fit the Tiger. It was not easy, we spent about a year working through cad modeling to get the shifter to the left side while maintaining a low profile body design. In order to get the transmission to fit proper, we have to replace the input shaft with a shorter model to move the transmission forward. This also allows the transmission to use the stock six bolt wide pattern four speed bellhousing. Our goal was to use as many factory parts as we could. If the Tiger is equipped with a six bolt bellhouisng, the only part that has to be changed inside the bellhousing is the clutch to provide a 26 spline clutch hub. The stock flywheel and hydraulic retained. As mentioned, the case has to be machined in several locations to provide the clearance necessary to clear the transmission tunnel and crossmember. We do offer the Tiger TKO600 with different gear ratio but most choice the TKO600 with a 2.87:1 first and .82:1 overdrive. .64:1 od is also available. For those who don't wish to change a clutch the 10 spline TKO500 with a 3.27:1 first and .68:1 od is available. I would recommend changing the clutch however and choose the TKO600 with the .82OD.
One of the nice options we offer a shifter that will allow the stock four speed Tiger lever to transfer the TKO. This both saves money and keep the "look" of factory. For those that want a Hurst lever or purchase an aftermarket shifter, we offer a shift stub. For those that are shift above 6K rpm, we recommend carbon fiber lined synchero ring on 2,3,4 gears. These are $50 each. While the complete Tiger TKO package with a Quicktime scatter shield for those with five block 260/289 can cost at or above $5K, each package price is diffferently depending what what we supply. It is best that anyone that is interested in pricing contact us for a custom quote.
  #25
Old 05-04-2017, 09:31 AM
Member of C.A.T.
Default
If someone want to find an AMC trails shaft housing, which are very hard to find, I can provide a new T-5z WC transmission with a 2.95:1 with an optional .80:1 overdrive. We offer a complete line of T-5 bellhousing adapters and clutches.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
