I have done an 11" Spal pusher which is a thicker fan then the Slim jobs. I had to trim a bit of metal as its a little thicker and mounted away from the radiator like the Tiger article on cooling mentions is good for pusher style fans.
Lots of other folks have done similar.
For the mechanical fan I am going running a 15" flat faced flex fan. I have a shroud, but not sure if I'm going to run it.
I have the Mike hokenson front end and nothing in the way of the fan. Not sure how Dales stuff is set up but would expect the rack to fan clearance is no longer an issue. Or just get a smaller fan and electric.
Sandy
