California Association of Sunbeam Tiger Owners Forum
Go Back   California Association of Sunbeam Tiger Owners Forum > Tiger Technical - Personalized/Modified > Gearbox (wide ratio, 5 or 6 speed)
New Threads
Thread Tools Display Modes
Old 03-30-2017, 09:35 AM
ModernDriveline ModernDriveline is offline
Forum Member
Member of C.A.T.
Default Modern DriveLine Tiger TKO five speed
Modern Driveline five and Six speed conversion specialist.
Sunbeam owners can take advantage of a five speed overdrive transmission that truely bolts in with no modifications to the body with the shifter in the correct location. Shifter options allow for the stock four speed lever to be retained for the OE look. Only you will know its there.
If you like to drive your Tiger on long drives, the TKO600 with it 2.87:1 first and 1:1 four bolts up to the stock six bolt bellhousing. Overdrive ratios can ben a .82:1 (18%) or the .64:1 (36%). We recommend the .82:1 with a 2.88:1 axle ratio.
The TKO can be purchased as a complete conversion package with includes the bolt in Tiger TKO crossmember, custom 31 spline drive shaft, 26 spline clutch set with include Kevlar facings. If you wish to purchase just some of the parts to make your conversion, give use a call and we can discuss the many options available and provide a detailed quote for your needs.
Be sure to visit your website for more information.
Contact infomation
Modern DriveLine
25308 Arroyo Ct.
Caldwell, ID 83607
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.8 Beta 2
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
