FWIW I don't think it's comparable to the alger issue, and think doing that causes issues in that debate.
It seems the issue is about accuracy of a reproduction part, im not sure if the plates are meant to be an accurate repro for you guys or just look similar to the period black plates. Obviously the reflective lettering is to do with modren requirements, and I would guess its for the legibility of speed cameras etc in low light conditions .
In my state period plates are a big $ thing and can be bought and sold to put on any car. They are numerical on the early plates and were a large stamped plate with a vitreous enamel finish, they went from single digit to 99999 .... If you had a plate reissued they replaced it with the then current smaller plates with the original number... In the last 15 years with reflective numbers... If you have the original plates you can still use them.
Any single digit plate would set you back 1million + anything in 2 digit 500k and 3 digit over 90 depending on number.... Ironically I bet 88-888 is worth the most...
