Paul4223
Here's a chart of tire sizes that are more or less pertinent to Tigers... They may not all be available and may vary slightly between manufacturers but give you some idea anyway...
B382000446
Thanks very much, Jim. Looks as if I can go one size down, which would mean running a square setup 205-50-15's.
If those will fit on my wider rear wheels, and I think they would, I then would want to figure out how much lower I could nudge the gearing. Do you have a table for that?
Edit: Whoa! I just got the Excell sheet you sent, thanks again!
UPDATE: This looks as if it's the calculator I was looking for:
http://www.4lo.com/calc/geartire.php
According to this, I'd have to run doughnut size tires on the rear wheels to make a significant difference! Unless I'm reading it wrong.
