Go Back   California Association of Sunbeam Tiger Owners Forum > Tiger Technical - Personalized/Modified > Engine
New Threads
Reply
Thread Tools Display Modes
  #11
Old 05-08-2013, 08:32 AM
Duke Mk1a's Avatar
Duke Mk1a Duke Mk1a is offline
Super Administrator
Member of C.A.T.
Default
Quote:
Originally Posted by Moondoggie View Post
sexy red finish
__________________
Duke
B382002037LRXFE, TAC #739, Born on 5/3/66
454 HP, 445 lbs/torque
Gentle as a kitten that will rip your face off when the right pedal is put to the floor.
  #12
Old 05-08-2013, 01:46 PM
67 Tiger 67 Tiger is offline
Gold Forum Member
Member of C.A.T.
Default
Looks just like the nippon denso on my Harley. Or the one on my buddies Toyota.
  #13
Old 05-08-2013, 02:13 PM
Duke Mk1a's Avatar
Super Administrator
Member of C.A.T.
Default
Quote:
This unit is designed for the Ford application using the Manual transmission. The unit is similar to the IMI-106 but has a shorter pinion depth.
Genuine Nippon Denso starter motor coupled to our patented design.
Yup!
__________________
Duke
  #14
Old 05-08-2013, 02:52 PM
Twin Turbo Tiger Twin Turbo Tiger is offline
Silver Forum Member
Default
I just went to Checkers and got a starter for a 302 with a one wire and stuck it on and also got one for the other tiger that has my old 331 setup and both have been in for more than 3 yrs
I'm on a tight budget can't have all that high dollar stuff
And by the way I've had my MSD 6al and coil in the car for over 10 yrs and no problems and its all mounted inside the car in the foot well on the pass. Side :-)
  #15
Old 05-08-2013, 04:10 PM
Duke Mk1a's Avatar
Super Administrator
Member of C.A.T.
Default
Quote:
Bwwwwwaaaaaa Haaaaaaa Haaaaaaa
__________________
Duke
  #16
Old 05-08-2013, 04:31 PM
Moondoggie's Avatar
Moondoggie Moondoggie is offline
Platinum Forum Member
Member of C.A.T.
Default
[QUOTE=And by the way I've had my MSD 6al and coil in the car for over 10 yrs and no problems and its all mounted inside the car in the foot well on the pass. Side :-)[/QUOTE]
So your the guy the tech's would talk about !!! My first 6AL ignition was bought in 2000 and over the next three years I went thru a total of 6 ignition boxes for the same defect....over heated and failed components. One of the last Tech's that I dealt with said there was a guy that had one that was still working...so it must be you. Three years ago they finally redesigned the 6AL
from the ground up but I still hear about the failures from the Cobra guys.
Thinking about it tho...you might not be drawing much power with that punny small block motor...just saying
Moondoggie
  #17
Old 05-08-2013, 06:24 PM
TigerBlue's Avatar
TigerBlue TigerBlue is offline
Administrator
Member of C.A.T.
Thumbs down Not science
"you might not be drawing much power with that punny small block motor...just saying"
Dog,
The ignition system is blind to yours or my displacement inside the engine. Timing does not care. Distributor advance is not intimidated by wasted potential and I have never seen coils recommended for engines under say 5 liters only!
Think before you post about your bias to too much is just right. I think you have regretted it before. Most Tiger owners do not have or even want a stroker. My 260 is a hoot to drive. Not as fast as my 302 but not bad and actually better for most of my driving.
Try posting something that is positive and constructive. Please.
  #18
Old 05-08-2013, 06:27 PM
Silver Forum Member
Default
Moondoggie
I've never had any contact with anyone from MSD and I've heard of a lot of whinning about there stuff SO THAT MUST be you:-)
You must still be one of the purist that is running a generator and trying to make new technology work LOL
  #19
Old 06-08-2017, 04:47 PM
Roadpir8 Roadpir8 is offline
Forum Member
Member of C.A.T.
Default Hi Torque Starter vs Summit Starter
In preparation for installing headers I ordered a new starter. I found the Hi-Torque starter available from Sunbeam Specialties, Part# AS50G for $215.00. I also have on hand the Summit Racing Protorque Starters, Part# SUM-820055 for $201.97.
I ordered the Hi-Torque after seeing some recent reviews on the Summit Racing starter about heat issues and the solenoid. The Hi-Torque appears to have a sturdier build and is notably heavier than the Summit starter. Rick from Sunbeam Specialties said the owner of Hi-Torque has a Tiger, so I will be installing the Hi-Torque starter, fingering he has a vested interested in having the best possible starter for a Tiger.
https://www.summitracing.com/parts/sum-820055
http://www.rootes.com/catalog3color.pdf
Click image for larger version
Name:	Starters Front.jpg
ID:	10013   Click image for larger version
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
