Go Back   California Association of Sunbeam Tiger Owners Forum > Tiger Technical - Stock > Gearbox
New Threads
Reply
Thread Tools Display Modes
  #1
Old 04-16-2017, 01:36 AM
steven steven is offline
Platinum Forum Member
Member of C.A.T.
Default Diff yoke bolt
What is the accepted method of tightening the bolt holding the yoke to the pinion. The Tiger is on stands and the assembler told me the nut needed to be tightened. If I fit the wheels and lower the car, there is no room for a wrench.
  #2
Old 04-16-2017, 02:50 PM
67MKII 67MKII is offline
Silver Forum Member
Member of C.A.T.
Default
Just off the top of my head - I would try setting the parking brake.
John
  #3
Old 04-16-2017, 06:58 PM
Theo_S Theo_S is offline
Administrator
Member of C.A.T.
Default
Quote:
The torque spec for that nut is significant, and the parking brake may not hold enough to let you tighten it properly. Make a 18 inch or 2 foot long torque bar from a piece of 1" square 1/8" wall tubing, that has holes drilled so you can bolt it to the U-bolt holes on the yoke. Bolt it to the yoke, and then use one hand to apply force to the torque bar and the other hand on the torque wrench.
  #4
Old 04-16-2017, 11:54 PM
Forrest39's Avatar
Forrest39 Forrest39 is offline
Gold Forum Member
Member of C.A.T.
Default
Not to get too dub-T, but add to John's idea a few 2x4's and a few bar clamps to the wheels to increase the arm and you will be able to snug that gland nut up no problem. I've done this a number of times....
Cheers, -Kevin
__________________
"...I must be honnest here; I love driving it - It is so choice. If you have the means, I highly recommend picking one up." -Ferris Bueler
1965 Mk1. B9470719. TAC#1069
1966 Mk1. B9471488.
  #5
Old 04-18-2017, 01:08 AM
Member of C.A.T.
Default
Thanks for the idea's, used a similar design when I removed the rear axles some years ago. A long bar bolted to the yoke to reach the floor will do nicely
  #6
Old 04-18-2017, 10:47 PM
Tiger tamer's Avatar
Tiger tamer Tiger tamer is offline
Gold Forum Member
Default
may be of help to you
http://www.sunbeamtiger.co.uk/forum/...ghlight=pinion
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
