NEW David Kee Toploader
Going in a different direction -
Brand New David Kee Toploader 4 speed transmission. This is the length for the Tiger, Aluminum case with the cast iron output housing.
2.44-1.69-1.29-1 Custom Ratio from David Kee (Between wide and close ratio) See what the rpm/miles/per look like in each gear -
http://gtsparkplugs.com/GearCalc.html (select Sandy's Toploader from transmission menu)
Does not include anything else, no crate, no shifter, etc. A few other parts might be available as additional cost, but are not included.
I'm not sure if this will fit early 5 bolt bells, but my plan was to use a 6 bolt one with this so was never a question.
I WILL NOT SHIP THE GEARBOX, BUT I WILL HELP LOAD IT :)
*** Almost forgot, I'm in the Los Angeles Area ***
$2000
Here is a couple of pics. It may support old and new bell housing patterns. Again, shifter and linkage not included.
Sandy
I am going with 3.56 or 4.0 with larger diameter tires, I have 275-40-17's on the back.
Sandy
Now including plastic shipping case and new Hurst shifter and linkage, and a lever with a ball. Again every part is BRAND NEW, not rebuilt. Ready to drop in.
Sandy
