Yet another Alger...
Steel Repros
Does anyone have a source for the engine hanger brackets? Either real Tiger, or a replacement part that is functionally the same? I can make them, but don't want to "reinvent the hanger" if I don't have to.
We make steel repros. Photo shows orig & repro side by each, eh. I'm not convinced that I would trust the frame bolt threads in the UK aluminum versions.
Jeff F
OK, back to the accessory drive.
I have my "temporary" 302. It's got a later style timing cover for a cast iron pump, so I'll need to swap that to an earlier one so I can put an aluminum pump on it. I've seen reference to the dipstick hole being different for generator vs. alternator. Is this really significant?
Is it possible to source crank and water pump pulleys, and an alternator bracket that match the Tiger? Are these parts unique or from something else? Is there an aftermarket option that is as shallow?
I already have a water pump pulley so technically I don't need that.
