Just curious if there is an easy way to tell the difference between the manifolds that should be on the left vs. right. I know that they were originally different colors, but now all four look the same. I have clearance issue on the left side to the point where the manifold is resting against the left engine hanger and the bolts to hold the manifold to the #5 exhaust port are either not installed or snapped off. Clearly something is awry. I'm wondering if I should try a bit of mix and match to find a configuration that doesn't result in clearance issues. Also, can any body suggest a source for manifold gaskets for the bottom of the tri-y header to the down-pipe?
Thanks! -Kevin
Thanks! -Kevin
