Guys
I had a Lockheed brake booster fitted by local jaguar e type garage whom I've stopped using.
He changed the system out without even asking and when it got here never worked. Felt as if the servo was not working in anyway. No improvement on the old system.
Just changed out to dales suspension system which is great, brakes not really improved however.
Just noticed the metal one way valve which should be pointing to the servo is indeed pointing to the engine manifold.
So swapped it, but now brakes are on so hard I cannot move the car.
I've switched it back and again feels like no servo, but when vacuum is on, car is solid and so is the foot brake.
Any ideas?
Do I have to reset everything, if so what..
Sean
Any ideas?
Sean
