Go Back   California Association of Sunbeam Tiger Owners Forum > Sunbeam Tiger > Your Tigers Story
New Threads
Reply
Thread Tools Display Modes
  #31
Old 07-16-2015, 12:12 AM
JB66CAT's Avatar
JB66CAT JB66CAT is offline
Silver Forum Member
Member of C.A.T.
Default Primer
I've been down with a bad back for a few weeks now but, my guys are making progress. Mostly in primer now. Doing the valance now and then the windshield will come off and prepped before final paint. Gaps all look good. (the hood is just sitting on it now). Also a pic of the dash and the shifter. The shop that the PO used did a nice job(IMHO) of extending the trans tunnel for the T5. Gonna need some extra carpet for that.
__________________
Jim B382000364
  #32
Old 07-29-2015, 12:03 AM
JB66CAT's Avatar
Silver Forum Member
Member of C.A.T.
Default New Valance
Took a month to get and just in time to install. Sunbeam Spares.
__________________
Jim B382000364
  #33
Old 07-01-2016, 03:18 PM
JB66CAT's Avatar
Silver Forum Member
Member of C.A.T.
Default Paint
Finally
__________________
Jim B382000364
  #34
Old 07-01-2016, 07:22 PM
cobrakidz's Avatar
cobrakidz cobrakidz is offline
Unobtanium Forum Member
Member of C.A.T.
Default
Looks good, now the fun part - assembly.
__________________
6 Tigers - all gone
66 GT350
  #35
Old 07-01-2016, 11:43 PM
JB66CAT's Avatar
Silver Forum Member
Member of C.A.T.
Default fun stuff
Quote:
Thanks, most of it was there, and with a lot of help from Rick at SS, the good people here, Dale's, eBay, and scrounging, I think I have it mostly covered. A pile o' parts going to the plating shop!
__________________
Jim B382000364
  #36
Old 07-02-2016, 01:59 PM
Forrest39's Avatar
Forrest39 Forrest39 is offline
Gold Forum Member
Member of C.A.T.
Default
Looks great Jim! What kind of paint is that and which color? It has a really nice depth to it.
Cheers, -Kevin
__________________
"...I must be honnest here; I love driving it - It is so choice. If you have the means, I highly recommend picking one up." -Ferris Bueler
1965 Mk1. B9470719. TAC#1069
1966 Mk1. B9471488.
  #37
Old 07-03-2016, 11:11 AM
JB66CAT's Avatar
Silver Forum Member
Member of C.A.T.
Default Kolor
Quote:
Cheers, -Kevin
Thanks Kevin! House of Kolor Green custom mixed with minimal pearl and black. No flake. Over two coats of black primer. Finished with two coats of clear. I'm calling it American Racing Green. ;-)
__________________
Jim B382000364
  #38
Old 01-18-2017, 12:15 AM
JB66CAT's Avatar
Silver Forum Member
Member of C.A.T.
Default Now for the differential
Going to re-fit the rear with a posi unit. Here are some pics of the rear end all cleaned up. Orange coating inside. Red oxide outside (what's left of it). Found those numbers too! I don't think it has ever been serviced.
Click image for larger version
Name:	tiger rear 3.jpg
ID:	9739   Click image for larger version
Name:	tiger rear 2.jpg
ID:	9740   Click image for larger version
Name:	tiger rear 4.jpg
__________________
Jim B382000364
  #39
Old 03-11-2017, 12:39 AM
JB66CAT's Avatar
Silver Forum Member
Member of C.A.T.
Default And so it goes
Funny how things evolve. The rebuild rear end and posi are in and painted.
Engine: The engine in this car when I bought it, as I have previously stated, was a Boss 302 with heavily worked 289 heads and a Rhodes cam and lifter set up which I was dubious about. It was built back in the late 80s by a hot rod shop. I did get it started and it was very lumpy. I worried about all the seals etc. after a 25+ year snooze and I kept thinking about the possibility of having to re-do it after getting it all back together. Plus, I wanted to paint the engine compartment. So, pulled the engine and replaced it with a new 347 stroker with aluminum heads. It already had the T5 so I replaced the ring and pinion set with 3:31 gears. (also running 15 inch wheels) It's back on the ground now and ready for rewiring and dash refurb. Did some clean up on the front cross member, brakes, rack, etc. and re-painted the parts. More to come...
ID:	9881   Click image for larger version
ID:	9882   Click image for larger version
ID:	9883   Click image for larger version
ID:	9884   Click image for larger version
__________________
Jim B382000364
  #40
Old 03-25-2017, 08:22 PM
MT Roads MT Roads is offline
Bronze Forum Member
Member of C.A.T.
Default Details.....
Just found this thread. The car is looking better and better! A lot of good work already done, and just a bit more to go. Congrats!
You may have already heard some or all of this, but here are some of the details about the previous rebuild of that car.
The Boss 302 Block also has the Boss 302 Forged Steel Crank & OEM Rods [shot-peened]. Those items alone should be worth something to someone, should you decide to sell it separately. The Head Bolt holes in the block have been heli-coiled & ARP head studs used, in case the heads have not been removed yet.
The engine was built with 12.5:1 Compression. Perhaps not the best plan for a street build then [& not my idea, nor that of Mike, the engine builder], but sometimes the wild hair takes root. So the pistons would need to be changed if someone wanted to build something milder for the street.
The engine was built by Mike Partlow of “Mike Partlow Racing Engines”. Mike had a side business building engines in his garage at night. Some of these were short blocks to order for Speedway Motors a Speed Shop in Santa Fe Springs [moved to Azusa, last I heard], others were to order for a variety of cusotmers. the business was mostly to earn extra $$ to support his racing habit.
His last major personal project car was a 56 Chevy 2 door street car that was Concours quality.
Prior to that, he had found a cheap salvage 1972 Mitsubishi Colt project car & turned it into a tube frame drag car with a 427 sbc that ran in the 8s. Guys that saw it run still talk about it. Mike was a machinist for COLA Cranks for years, then went to JE pistons to help launch the SRP brand on the sales side when they were still in Huntington Beach. He passed prematurely and is still missed by most everyone who knew him.
Back to the Tiger. The engine & 5 speed install [and the trans tunnel work] was done by “Doc’s Hot Rod Welding” of Long Beach. Some of his work had been featured in magazines. When the engine was first fired up for the initial run-in, we discovered that the original Tach had been changed sometime in the past [prior PO] to one from an MGB or similar, as many did in order to have the face with 6K RPM red line rather than the puny looking 5K original. That owner was not aware apparently, or did not perform for whatever reason, the necessary tach conversion from a 4 cyl application to that for a V8. Therefore the tach was always registering 2x the actual rpm of the engine.
The brake system was completely rebuilt with new master & wheel cylinders, rather than rebuilding the originals. All of the suspension bushings & tie rod ends were replaced. A new exhaust system was fabricated when all was done.
When completed, the car needed to be smogged prior to registration. The smog shop struggled to get it to pass, and no doubt leaned it out a lot.
After the smog session, it was finally taken back home. Before it could get re-tuned for street use, the accident with the radiator occurred. That became the final straw in the rebuilding process. The owner at the time had other interests, job stress, etc. and decided not to indulge any more time & resources to it.
Best wishes for the rest of the project!
__________________________________________________
__________________
MT
...just looking for clues...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© California Association of Sunbeam Tiger Owners
