C4 SVO 302
The SVO 302 should be a 6 bolt bell housing, most c4 for small block ford should work, there were some early 5 bolt c4 transmission bell housings, but they are fairly rare, Then a new auto transmission flex plate in 157 tooth and same balance factor as your motor (could be the older 28oz arrangement or the later 50oz arrangement, just verify what yours is, both balance flex plates are available--- this would affect the motor some if you had a custom balance done on your SVO assembly, but would be like the factory balance). Not sure on the starter, the automatics MIGHT have a different starter gear engagement depth, or could be the same, a search of starters for manual and automatic cars would suffice, if they are the same part number they are the same, if different the gear depth is different, but both are available.
There is a right up in some of the Tiger Shop Notes that are available through CAT.
RB
