Fan shroud
tigresunbeam
Forum Member
Is there a difference between a MKI MKIA and MKII Fan shroud
I think the original one are made in one piece , some repro are spot welded !!!!!
Gilles
Looking throught Parts Supplement seem to have only one number for all series
Pinch Spot Welds Are Used
Gilles,
I looked at my Mk II's fan shroud. I cannot say for certain that it is original, since the car was involved in an accident shortly after I got it in 1970. They might have had to replace the shroud at that time. In 1970, Rootes replacement parts were readily available, so I have no doubt that the shroud is an original Rootes part.
Most of the shroud is made from a single piece. Attached to this are three other parts that are used to attach the shroud to the car. At the top of the shroud is a piece that is "L" shaped. It is attached to the main part of the shroud by pinch spot welds. Nearer the bottom of the shroud are the two "legs" that are used to bolt the shroud to either side of the radiator. Both of these also are attached to the main body of the shroud by pinch spot welds.
Hope this helps.
tiger260
Just checked my fan shroud (mk1 and off the car at the moment) and it is definitely made from one piece of steel apart from the 3 small pieces that David mentions.
I assume the radiator was the same part all through the Tiger's production so would have thought that the shroud remained the same too.
Rootes were watching the pennies so if they didn't need to change it, I can't see them doing so.
Mk II Radiator Was Different
The Mk II radiator was different. It used a plastic drain valve which was located on the opposite side, if I recall correctly.
canbeam
Hi Gilles
I have owned Mark 1's, Mk 1a and Mk2's and am 99.99% sure there was no difference in the fan shroud between them. My brother has had his Mk2 from new so will check next time I see it.
Ron
canbeam
Hi Gilles
I just looked at my original Rootes Parts Manual which includes both the Mk1 and Mk 2, and it only shows one part number for the fan shroud.
Ron
Function or Heredity ??
I don't particular care if it wuzz Rootes blessed, as long as it works . . .
tigresunbeam
Forum Member
I had one made locally ( Montreal)
Will be made of 3 pieces
Top 1 pieces
Side 2 pieces
Picture to follow !!!
Gilles
Thanks everyone
tigresunbeam
Forum Member
Made of 3 pieces instead of 1
18 Gauge instead of 16 not sure if original was 16 gauge.
I am very happy will be installed on my MKII to replace the fiberglass one .
Gilles
tigresunbeam
Forum Member
Fan Shroud
Made Locally , by someone who does steel body Patch.
He his very good with the English Wheel !!!!
Gilles
Reasonanle facsimilie
Your fab guy left out a telltale crease along the back of the area that appears like a balloon tire bike fender. The crease is in aprox. 1/2'' along the motor side of the curvy part. In all fairness the U.K. ones I have seen also have the same missing element.
tigresunbeam
Forum Member
fan
I think i understand what you have written
See attached picture of another car
Gilles
I have modified my repro shroud before painting.
Thanks again
That's it
Sorry have not been able to provide pictures. The crease may have some variation in depth and from passenger side to driver's side. I suppose it could be mfg. change or latitude or restorer's discretion.
tigresunbeam
Forum Member
Fan Shroud
Shroud installed , better then the fiberglass one I had on the car since 1998
The fiberglas one will be for sale later on
Gilles
tigresunbeam
Forum Member
One member are asking us to make another one .
We are not making that Shroud , We will need to take a shroud out of the car and have one made , so we will ask the thin bender to make anther one .
Look at the picture on the tread . If interested send me a note !!!
18 gauge instead of 16.
Missing also the 2 half hole on top of the shroud !!
Let' s me know if you are still interested !!!!
Gilles
