California Association of Sunbeam Tiger Owners Forum
Go Back   California Association of Sunbeam Tiger Owners Forum > Tiger Technical - Personalized/Modified > Brakes, Wheels and Tires
New Threads
Reply
Thread Tools Display Modes
  #1
Old 09-08-2011, 08:09 AM
Chris Major Chris Major is offline
Bronze Forum Member
Member of C.A.T.
Default Tiger Wheel/Tire Combo
I have a 66 Resto Mod projet I'm looking at and want to run larger wheels w/wider tires. Read an article on putting larger wheel/tires on 65 Tiger:
They ran a set of Superlite wheels, sized 15x6 inches up front (24mm offset) and 15x7 inches in the rear (25mm offset) w/a set of Dunlop Z1 tires 195/55R15 all around "nearly" stock wheel wells.
Anyone have experience w/his upgrade and if they have had to adjust wheel lip and valance (on finished car) to be "nearly" stock?
I'm looking at PSE S/C style wheels.
Thanks in advance,
Chris Major
  #2
Old 09-08-2011, 04:41 PM
michael-king's Avatar
michael-king michael-king is offline
Unobtanium Forum Member
Member of C.A.T.
Default
Chris,
Marks car runs the combo of panasports that Dale A sells, PSE also make 15x6 front and 15x7 rear wheels in the HSC55 style that fit tigers and run the correct offset.
You should be fine on the rear, just watch out the sidewall doesnt touch the pinch on the lip under hard cornering (oir if the car is sitting low) the front you might want to trim the front valence a little and would be worth rulling the pinch on the lip to avoid any contact.
the sizes you are talking about are now comon on many tigers
__________________
Michael King
1963 Alpine SII 1996>
1964 Tiger MKI 2009
1965 Alpine SIVGT 1994>
1965 Tiger MKI 2009-2012
1966 Tiger MKIA 2006>
  #3
Old 09-08-2011, 11:07 PM
cobrakidz's Avatar
cobrakidz cobrakidz is offline
Member of C.A.T.
Default
I am running 15x6 and 7 with 205/50 and 225/50 with NO rub issues at all. I believe this is the same size I ran on my last Tiger, Cleo Shelby's red Tiger.
__________________
6 Tigers - all gone
66 GT350
  #4
Old 09-09-2011, 12:26 AM
0neoffive's Avatar
0neoffive 0neoffive is offline
Member of C.A.T.
Cool Valence Trimmings
Photo shows 15 X 6's running 50 Series Tyres on an incomplete MK II. The valence was trimmed 3/4" at the normal contact point just in case.
  #5
Old 09-09-2011, 09:30 AM
cmjr1966 cmjr1966 is offline
Bronze Forum Member
Default PSE 15" wheels
I bought a set of PSE's off this Ebay auction(see pics), I already had a set just like it. 15x7 with 4.5" backspace. The Ebay wheels were advertised as 4" backspace and frankly the price was too good to pass up. My thoughts were if the 4.5's rubbed, maybe the 4.0"s wouldn't. The tires were made in 94(DOT numbers) and the seller said they were on the car when he bought it. This car was kicked around in earlier posts when it was wearing the PSE's and after when the seller pulled them off and sold them separately. In talking with the seller they didn't rub on the front, tires are 205-50-15's, Goodyear Eagles. First thing I looked for when I got them was scuff marks...any marks on the inside's of the tires or rims, they are spotless. I don't know if the car had been modifyed to take these tires and more importantly when I got them they were 4.5" backspace and not 4", basically I have 2 sets now, these and a set unmounted. Here are the pics the owner posted on Ebay with the wheels on the car in question and unmounted.
__________________
B382000737 TAC# 0839
  #6
Old 09-13-2011, 09:03 PM
Bronze Forum Member
Member of C.A.T.
Default
Thanks to eveyone. Phil at PSE confirmed that 15x6 x 3.75" back space and 15x7x4" backspace is what het typically puts on Tigers.
  #7
Old 09-13-2011, 09:37 PM
Member of C.A.T.
Default
Quote:
So the magic question... which ones are you getting?
__________________
Michael King
1964 Tiger MKI 2009
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.8 Beta 2
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
