Brake pedal ratio
I am calculating brake bias and line pressures for a disc brake mod
What is the brake pedal ratio? I have read 3.7 and 4.6 and would like to hear from someone that really knows as I am designing this from afar and cannot go measure for myself
Before I reinvent the wheel, is there a DYI mod to increase the ratio?
Tweak
Contact Tom Hall at tigerengineering.net
He does awesome work on the pedal assembly and knows the ratios and more.
modtiger
New forum user
Brake Pedal Ratios
The OEM Tiger/Alpine brake/clutch pedals have a mechanical ratio of approximately 4.4:1. I've been making kits for quite a while that modifies this ratio to 6:1, which is pretty much the standard aftermarket ratio. This gives you an advantage of about 1.36 over the OEM Pedal. This is almost as much as the vacuum booster gives you.
I also make this kit for several master cylinders from the OEM Girling to "new" Dual Masters from 13/16 to 1" diameter. Using a 13/16 diameter also increases your hydraulic ratio. The kits are complete, but you must send me a Tiger brake pedal (Alpines have a different bend) and the Pivot assembly. I can bend an Alpine pedal to near Tiger specs, but not "perfect". The process is reversible with the exception of the Pivot which I modify. I typically make several a year for Dale's customers.
I have also run my 6:1 kit with a booster and autocross pads, but be sure your seatbelt is fastened.
modtiger@comcast.net for further info.
That will do the trick with, and on paper at least, makes a huge difference in a non-boosted car.
Given the ability to change the pedal ratio, raises more questions:
What is a reasonable leg pressure on a street car to achieve max braking?
What deceleration rate can a street Tiger with "good" brakes achieve? I have been using .86 g as a WAG
My other WAG is the centre of gravity height. A better idea of the actual number would be a big help
It really depends on how fast you are going and how far/heavy the car in front of you is and what speed you hit it at. ... :eek:. .....
Sorry not helpful. :eek:
