IvaTiger
I am in the process of removing the engine from underneath after removing the front suspension. To reduce the amount i have to lift the body I want to remove the dip stick tube and choke tube , both do not want to come out My question is if the oil pan is removed can a punch / drift be used to tap the oil dip stick from the bottom and any ideas on getting the choke tube out or is it best to leave well alone ?
