Grease that shifter
IvaTiger
IvaTiger
If you have a rattle from your gearshifter you can remedy that by pumping grease down it. You will need to make an adapter with 1/2 20 threads on one end and a grease zerk on the other. Use hot glue to fill the holes where the reverse lock out is Then pump away , remove the glue and activate the lock out to get that grease really moving and repeat if you wish.
It also lubricates the spring loaded pads that hold tension on the lever Remove the adapter and replace the gear knob or leave it on as a custom job !
I heard grease is the word but that's Hollywood :)
I've used a spray can white lithium grease. It's certainly my linkage that likes to need a shot now and then.
mr55s
On a warm day my shifter body/shaft gets pretty warm, I would wonder if the grease would melt and then your back to the rattle again.
If you can hear that rattle, yer motor ain't runnin'
IvaTiger
Use Redline CV2 synthetic red grease it is good to 400 degrees
