Konis
From what I remember, the shockies cannot be adjusted on the car. They must be removed. You then push the centre shaft completely down. This engages the shaft with a valve at the bottom of the shock. You then rotate the shaft to increase or decrease the rate. I seem to also remember that the shocks were set in the factory, and the adjustment was mainly to compensate for loss of stiffness as the shock aged.
Grelley
