It's interesting to see many different solutions, some seem to conflict with other books I have seen. I think in one of them they mention that they want the rear spring location higher then the front for accel/decel reasons. Have not really looked at this on the Tiger but will see how they look relative to each others.
Getting rid of rubber is one thing that most all articles mention, either solid bushings or spherical, but main thing is to get rid of that rubber. The CAT springs have the smaller bushings on both sides and reverse eyes which I think are good for this car, and if making solid bushings all are going to be the same.
But I am cautious with these springs now a bit as DW mentioned they are about flat at ride height and that may not be so great. I have to put a few things back together and really get a look with some weight on the car.
Also on wheel hop I have seen this mentioned a few times that all front spring ends should get the band clamp on each front facing leaf to help the front part of the leaf do it's job as a control arm. This may harsh up the rid a bit but the consensus is that it helps.
Given that the finished rear suspension will have some very wide tires, big brakes and the motor will be making more hp then will ever be needed (well maybe not), I am trying to head off the wheel hop issues with some ideas others have tried (Like band clamps on the front of each leaf end).
Spring bars are another option, they work like the caltracs but are spring loaded in one direction. These may be a bit better but I hate bolting up more crap to the car.
One other thing that I had not thought of, since the car has coil over shocks (only shock being used) some additional spring could be put in to offset a fixed lower rate leaf spring with some adjustable coil over help, can change some of the rate and ride height very easily. (may be stretching it here).
Thanks for comments and feedback soaking it all in...
Sandy
