I'm prepping a Tiger for a long August road trip.
It doesn't run an expansion tank and is equipped with a large Aluminum two row single pass radiator and a stock water pump. The horn holes have been blocked.
With traditional 50/50 water coolant it ran much too cold at cruising speeds even with a thermostat. It has idled for a half hour in over 100 degree heat.
I've decided to try an experiment and install Evans waterless coolant which is mainly propylene glycol. I have serious doubts that this will work well but I'm willing to try new things. Maybe I'll get lucky. However, in the spirit of trying to not reinvent the wheel, has anyone had experience with Evans in a Tiger?
Buck
Buck
