Rear front bush removal
I need to replace the rear spring front bush. I need a 47mm steel pipe or a 1 27/32" pipe. Has anyone done this and have the required pipe?
Cheers
Steven
Hammer & Chisel
Cheers
Steven
Steven: There is a small gap where the spring is wrapped around the bushing. It's possible to drift (drive) a cold chisel point into the gap from the sides and thereby spread the wrap enough to be able to drive the bushing out without a lot of struggle. Been there and done that several times . . . .2-cents
tiger260
What he says ^^^
