How does the rear waist roll attach/detach? Want to remove it gracefully so that I can reattach the Soft Top Boot that pulled away. Looks like the boot gets hooked via a spur of metal piercing it.
You have the top boot attachment correct. The roll is attached via spring steel clips that engage when the roll is pressed downward, clipping into a slot in the divider. Don't pull it forward or they will break. Pulling upward should release them, but the spring steel can break.
