My daughters Ford 302 Explorer has developed a miss- unfortuneately its a valve.
Researching what's the best options, the 302 is stuffed in tighter than Tigers. It may be easier to pull the engine and replace with a local Craigs list motor.
I REMEMBER THAT LATE MODEL 302 EXPLORERS HAD GT40 HEADS. The 1997-2000 Explorer GT40P heads flow 196 cfm @ .500 lift. which is close to some aluminum $$$$ aftermarket heads. My 289 on the engine stand has 10.5 to 1 pistons. With the 1997-2000, F77E-AA HEADS AT 60 cc it would bring the comp ratio into regular gas territory. I think that the Craigs list motor can be bought for less than $200.
Refer to:" http/www8ji.com/small_block_ford_heads.htm" courtesy of Tom Rausch for flow data on Ford heads.
May need ROL head bolts from Oreillys for $30.00.
ROGER
ROGER
