My top loader tran had a problem shifting into reverse, no problem with the other 4 gears. I sent the shifter to Bill Heeley vintage Ford Shifters and he went thru it. I set the trans levers into there neutral positions, placed the alignment pin in the shifter levers and tightened the shifter rod nuts. I can shift into 3 or 4. No problem. Can't shift into 1, 2, or reverse. Would any one have any suggestions on what might be jamming this up? I did not remove the trans side levers or change the shifter rods. Thanks Bill
