Some time ago I submitted the way to decrypt the fastener parts numbers found in the Alpine and Tiger parts books. Some additional notes for the more anal among you that want to use correct fasteners.
Rubery Owen was the manufacturer for all of the fasteners found on Alpines, Tigers and the great majority of all English cars.
Screws were either zinc plated or chrome plated. Chrome screws could either be steel or brass, it depends on the use and strength required. Bolts and set screws could have been unplated (plain), zinc, or phosphated. There are rare occurrences of chrome plated bolts. Stainless fasteners were never used on these cars and in the case of suspension parts, are completely unsafe, and should NEVER be used.
Washers were "Imperial" sized. They have a much smaller outside diameter that a normal SAE washer. Helpfully, metric washers have the same outside diameter as an Imperial washer.
Screws on MK1 cars were either slotted or Phillips. Sometime in the middle of Series 5 Alpine and Mk1A Tiger, Phillips was replaced by Pozi-driv screws. These can be distinguished by marks in the screw head at 45 degrees to what looks like a Phillips slots. Pozi-drive screws can be removed by a Phillips screwdriver, but cannot be really tightened w/o using the correct pozi screwdriver.
Head markings on English bolts have a depressed center and script around the perimeter. The vast majority of the fasteners on Alpines and Tigers are marked "AUTO" and have a suffix letter of "S" or "R". Not all of the bolt heads are so marked. 10-32 threaded hex headed set screws are usually unmarked. I have found scattered 1/4-28 bolts that are marked "SPARTS" or "WILEY" and some marked only with an "S" or an "R". A good rule of thumb is to document what you finds an put it back where you found it.
Generally fasteners that were painted over, were bright zinc plated. Parts that were left unpainted were phosphated (black oxide). I have a company I use in Spokane that can clean a zinc plate fasteners, hose clamps etc... they can also phosphate parts for me. the cost is quite reasonable Usually about $50 for a 5 gallon bucket and I don't have to clean the parts first.
Lockwashers... The vast majority of lockwashers used on Alpines and Tigers are internal tooth type. exceptions are on flat head or oval head screws where the lockwashers are beveled external tooth. there are outliers that are standard cut type lockwashers, but there aren't a lot of them on the cars
