Odd !!! When I asked him, the answer was "negative". Do you have a part number?rick at SS sells bearings and felts
Maybe that was Larry?Odd !!! When I asked him, the answer was "negative". Do you have a part number?
Tim uses fatter steel for the cups which improves durability. The balls are a bit smaller to keep dimensions.Back in 2017, Tim stopped making steering shaft bearings and races. I was able to get a set he still had for my restore. His bearings are much better than the stock bearings. Grab a set if you are considering a rebuild. Cliff
