Hi my Tiger has slow speed running issues since it started. It will start and run at 3000 and up. Once it gets near 2000 it stops. It is a fully rebuilt 289 with alloy heads and a 4 barrel holley. I took it to a mechanic and he even changed the carby to try to fix the problem. I now have the Tiger back and still have the problem. He said it has a vacumn leak most probably between the inlet manifold and the heads, Is this a common occurance with new parts? If so I will have to lift the inlet manifold and have the gaps checked.
