Parts for Sale Tiger MkII Headlight Rims
canbeam
SOLD I am finally sorting through my huge pile of boxes, bins, and loose Tiger and Alpine parts accumulated over 50 years, and came across a pair of Tiger Mk II headlight rims. They aren’t perfect, but with a little TLC, quite usable. As you can see in the attached pictures one rim is missing the rear upper mounting bracket, and the other mounting bracket is loose as it is only fastened with one rivet. I believe the mounting bracket for the earlier Mk1 peaked rim is the same, but they used all three mounting holes, unlike the MkII rim, where only two were used. You would need to scrounge one from a Mk1 rim or make your own. One rim is nicely round, where the other has a very slight flat spot where the lower mounting screw was over tightened. The one with the bracket has a very small chip on the side trailing edge.
