The bottom line; none of it is simple or inexpensive. There is an adaptive process no matter which direction you take. The end result is quite nice once done.What is the simplest closest to bolt up 5 speed conversion for a 65 Tiger.I'm sure that the Tremec transmissions are great transmissions.But they are a little pricey and it seems like a fair amount of work to install one.Is the T5 still a good option
It depends if you want a straight bolt in ...no cutting no metal massage conversion...or you can handle some cuttingWhat is the simplest closest to bolt up 5 speed conversion for a 65 Tiger.I'm sure that the Tremec transmissions are great transmissions.But they are a little pricey and it seems like a fair amount of work to install one.Is the T5 still a good option
One Tiger owner from my area has owned Tigers since the mid 60's. If he was restoring a car and the owner wanted to deviate from stock he always said "Some modification required". As Randy said, it's not easy and is expensive.I
Given there is a kit that is a straight bolt in with no mods ... It very easy ..but that kit is expensive.One Tiger owner from my area has owned Tigers since the mid 60's. If he was restoring a car and the owner wanted to deviate from stock he always said "Some modification required". As Randy said, it's not easy and is expensive.
