During the past week the Mark II I am bringing back from the dead has experience hard starting when hot. Since I have been working on it, I have replaced the points with a Unilite (inside an older Mallory dual point), I have put on a new Mallory coil, and a new set of MSD wires. I have not changed the ballast resistor, and it may well be original to the car.
Yesterday I almost got stuck at a restaurant, and had some friends with me to help diagnose. The carb is getting gas fine, but it appeared that it was not getting spark. While another cranked, I momentarily bypassed the resistor and it fired right up. I immediately reconnected to the resistor and the car ran OK as I took it home.
I suspect the resistor is opening up when it gets hot. I know SS has replacements, but I have a couple that I have not used in the past laying around. Does anyone know how many ohms the resistor should be, and what the voltages should be before and after the resistor when the car is running?
Also, is there a particular replacement I can run to the NAPA/Pep Boys and purchase as a quick replacement?
Any input would be appreciated.
