Since I had moved the Dash towards the driver a bit by using isolation mounts I ran into a few issues. One was the mounts one each end needed an extension bracket, and seems also I need to make them for the bracket that attaches to the steering co0lumn support. This is an easy one, and easy to tighten for a change as the side ones were difficult.
I used blue Dykem which is not as accurate as red, so holes not perfectly centered when I drilled but not a big deal.
Moving along...
Moving along...
