A BIG thank you to Duke for this one.
Before adding a cooling fan, make sure that your ignition's vacuum advance is connected to manifold vacuum, not carburetor throttle port vacuum.
You are welcome.
Duke.....
What is the timing advance when first cranking the motor ??
There is not any vacuum advance when cranking. I run 12 degrees static. So 12 is the answer.
Actually there is vacuum otherwise your carb wouldn't work. I know allot of guys do this on race engines with big cams but race engines don't go
50,000 miles. I would be more concerned about detonation for the first couple of minutes while the motor warned up.
Moondoggie
Dawg, are you mess in with me or what??
No vacuum during cranking, accelerator pump shoots fuel into manifold and is sucked into engine. Cranking rpm is very low so if there were any vacuum it would be very low..will measure cranking vacuum if any once I am home. No detonation under idle conditions as the engine is not under load. Who drives any engine hard till it's warmed up anyway? Any application of the loud pedal and vacuum is gone.
Duke,
I would never mess with anyone that has the patients and fortitude to speed a year away from his family and Tiger just 18 miles from the Korean DMZ...You deserve big thank you from me.....
You are welcome, its a job someone has to do.... With that, cant wait to get the hell out of here. Waiting to turn in my gas mask the day before I fly just to be sure.![]()
I can relate to that !!! I spent a year (1968) at a remote Air Force radar site,
King Salmon Alaska. When it was time to return state side I was flown to Elmendorf AFB and turned in my artic wear. Then was told it would be a five day wait for the next Air Force seat to Seattle and was given a room at the transit barracks. A year is a long long time as you now know, so I took a taxi cab to Anchorage International Airport and bought my own ticket home to San Francisco. Spent the next two weeks on leave and then reported for duty at Fortuna AFS in North Dakota...The Air Force never asked how I got home from Alaska. The service is probably different now.
Moondoggie
#382000428 was at Elmendorf for awhile while Capt D was extracting and other stuff in S.E.A. (I was at E.AFB too...very briefly). A number of Ti's parts, front grill, air cleaner and steering wheel and original steel wheels went missing right around that time frame... hmmmm.... They couldn't find the USAF shipping ledger, the boxes just seem to have gone AWOL, as if they got on a separate flight...
mysteries... make life more interesting...
I have settled on 15 degrees of initial static advance, 23 degrees of centrifugal advance (all-in at 2600 RPMs), and 12 degrees of vacuum advance at 15" or higher vacuum. I have found that this combination works well on Ford small blocks with up to a 9.5:1 compression ratio and a mild cam. With higher compression ratios you will need to back the initial static advance down a little.I would be more concerned about detonation for the first couple of minutes while the motor warned up.
Moondoggie
My vacuum advance doesn't even begin to pull in until there is at least 8" of vacuum, an engine won't develop anywhere near this much vacuum during startup cranking.
One does not need to be concerned that much with detonation during warm-up because the engine is running so much richer when the choke is partially closed than it does at normal operating temperature when the choke is wide open.
