Trial fitting the dash so I can get the wiring harness routed to the bulkhead connector. Found out one of the relays is too close to the edge and hit the dash bracket. Lucky the relays could be stacked a different way to make room. Got a tip to space the dash closer by 1/2" or so with isolators which helps in another area.
One problem is lower dash pad has 1/4-28 threaded studs, and isolators only come in 1/4-20. Drill, tap and vice grips solve that issue.
The extra spacing works since I'm not running a dash pad, will help with the gap a bit.
Pics for your enjoyment...
