A simple test light should verify good contact as the arm sweeps the coils. For safety design, the contact "brush" is broad enough to span more than one coil or three-ish to prevent an arc. If it actually falls between two coils, there is arc potential. Inspect carefully. AmenThis MKII unit wasn't working so I removed it and split it apart. Does anyone know if these windings look correct or have they been shifted around? This has a totally different construction than the one in my MKI.
