I'm finishing a MKII restoration for a friend of a friend of a friend and have discovered a leak in the header tank, which had been chrome plated. It's a very slow leak but water was showing up on the frame rail below the tank. It's so slow that I couldn't locate the exact spot of the leak on the tank with it in place. My best guess was the joint between the two halves of the tank which I had dealt with on my own car many years ago.
I removed the tank and a pressure test at a radiator shop revealed a very straight crack running about 2" long ways along one half of the tank on the bottom side. Fortunately, it's in a spot that won't show when installed. The seal between the two halves of the tank is in great shape. The radiator guy was willing to grind the chrome away just enough and try to braze it up but did not have good luck with that. There is now a crack/leak on the other side of the tank directly in line with the old one. It seems that this will be an ongoing process, seal one and create another etc. I'm thinking this is not likely corrosion because of how straight the lines are.
Has anyone experienced anything similar?
I'm open to suggestions but because it is useless as is, one possibility would be splitting the two halves, seeing inside and hopefully being able to repair from the inside. The fact that it's been chrome plated only complicates things but I'll just have to deal with that.
Thoughts, suggestions?
TIA
TIA
