Oil cooler protection
sandy
Added a nomex honeycomb radiator shield to the expensive oil cooler to keep rocks, bolts etc. From punching a hole in it.
Basically made a new bracket that bolts to the bottom of the cooler support with a slot to capture the honeycomb shield. The material is 1/2" thick.
Had some wide and short aluminum angle that worked well.
Did some countersink screws and fitted it up.
Also painted the honeycomb flat black because.
Pictures not Uploading from phone, stand by...
