You think its not a daily driver? Really?I would say it's not a car intended for every day use on the highway so upon close inspection you would find many pieces not installed. A short person would have a tough time seeing over the front of the car.
Yes! I really think it's not a daily driver. Look around it and you would probably find quite a few pick ups and suvs.You think its not a daily driver? Really?
That's because it's intended use is a drag strip. that last thing you'd want to do... is turn!Im not sure the scale of the metal flake matches the size of the body..... But That's probably the LEAST concerning thing... 😨
I mean.. The grill mod means it has no parking or indicator lights..... 😂
I spent a lot of time back in the late 60's and early 70's at drag strips crewing on a 55 Pontiac that raced in stock class. Cars like this Rapier were called a gasser. Steering got a little touchy if the front wheels weren't on the ground. There was a guy in Huntington that built a gasser using an Austin Healy 100. We told him then that he wasted a valuable car.That's because it's intended use is a drag strip. that last thing you'd want to do... is turn!
