Throttle-Cable Mounting Bracket
Steven43
New custom-made Tiger throttle cable mounting bracket. This bracket is somewhat patterned after the LAT bracket from the 1960s. If you are using an F4B intake manifold, stock-length throttle cable and a 4 barrel Holly Carb(4150 or 4160) this mounting may work. I say may, because one has to factor in motor mount size and where the throttle hole is in in your trans tunnel. This part may not work if one uses a different style carb. It may not work at first, even if you have all the right parts. But it is a good starting point! It took me 6 hours to make the first one and get full open throttle with minimum binding of the new SS cable. (Good Luck!) US shipping only. $55.00 pulse $6.00 shipping (US shipping only) Steven Alcala PH 310-941-0659 voice mail only-no text
