I remove and install the trunk springs by removing the prop bracket from the deck lid because it lets you get the spring in the most relaxed position. This one was fighting me going back in, even using this method. I remembered a tip I had read on installing hood hinge springs. I put the spring in a vice and by flexing it sideways, slipped a bunch of pennies between the coils elongating the spring. You can add as many as you need. They easily stay in place because of the spring tension. Now the temporarily stretched spring is much easier to hook into place. I used the prop lever to stretch it a bit and pull the pennies out. Washers would work too.
