Upgraded Wiring Harness and Turn Signal Question
mechachy
I've scrapped the stock wiring harness. My friend is an electrical contractor and hot rodder and his harness of choice is the Ron Francis kit. Since I know practically nothing about wiring, he's asked what people are doing with the stock Lucas turn signal switch to make it compatible with the aftermarket harness kits that are out there.
Well, the first question would be, "what's wrong with a stock harness"? I've been restoring Brit cars for over 40 years. I always fit new wiring harnesses to the cars I restore and these are supplied by Autosparks in the UK. These come correctly configured with the proper wiring colors and are set up for the original electrical components used (gauges, generator etc.
The Ron Francis harness will not work with your stock tachometer and you will have to make a provision for the voltage stabilizer for the fuel and temp gauges. It may not have a provision for the pressure switch for the brake lights. I may also not work with the 2 speed wiper system or the 2 speed fan.
It's a myth that there is something wrong with "Lucas" electrical systems. 9 times out of 10 it's a ground issue, a corroded snap connector or that someone else has gotten in before you and "improved things".
Yes, there are only 2 fuses in the system... the same as Healeys and MG's and most Triumphs too... If you want to add additional fuses it's not all that difficult.
Most of the wiring problems I see are due to confusion over polarity as most English cars prior to 1967 are positive ground. This isn't the case with Tigers.
If this is due to wanting to install an alternator they can be easily incorporated into a Mk1/MK1a harness without cutting or adding wires VERY easily.
This was my dad's car. Stock gauges are long gone. Stock wiring harness fairly chopped up due to all the mods he made.
I just had a car come in a few months ago... someone had attempted to install a Ron Francis harness... Nothing worked. I just ordered a correct harness. A lot easier as everything is the right length (wiring harness feeds) so it installs quickly... Gauges are all available new.
Rootes (and Lucas) spent some time engineering everything to work properly. No point in reinventing the wheel.
I installed a harness from Pete Almjeld that's unfortunately no longer available. I cut off the original bullet connectors on the turn signal switch and crimped on spade style connectors to plug into the new wiring. I don't know how the Ron Francis kit is set up but Pete's was based on a Rebel Wiring harness and had everything needed, even a connection for a third brake light.
-Jon
i used a rebel wiring harness which easily supported std turn signals so assume your will do the same. Then to add emergency flasheres found this video which was a big help
