Tiger:
B9471022LRXFE
1965 Sunbeam Tiger, Certificate of Authenticity from Sunbeam Tiger owners Association, Nevada and Northern California car all it's life, no expense spared restoration, 100% rust free car, taken down to a shell and repainted the original beautiful British Racing Green, polished to a mirror finish, all new Black interior, restored Black removable hard top, comes with rolling hard top cart and soft cover,
Engine is a 1986 302 5.0 roller block, standard bore, forged pistons with Moly rings, E303 cam, Flo tech aluminum heads, roller rockers, TCI airgap manifold, Edelbrock 650 carb, Boss 302 baffled oil pan, Pro Comp HEI distributor, custom oil cooler with relocated filter, 4 row radiator with dual pusher fans.
rebuilt front suspension with urethane bushings, Addco 7/8 front sway bar, traction lock rear end with 3:54 gears.
Wilwood 11.75 front disc brakes with braided lines, rebuilt rear drum brakes, Wilwood clutch master cylinder, updated OEM style 8K electronic tachometer, McCloud clutch kit, Ford Top loader 4 speed transmission, Power master 75 amp 1 wire alternator, custom Billet alternator bracket, Flowmaster dual exhaust, Marth Wheat upholstery, heater works great, solid walnut dash with 10 coats of clear, 15" Uniroyal Tiger Paw tires mounted on Staggered Rota Mini lite wheels, car has around 3000 since a complete restoration, car starts instantly even after sitting, runs and drives excellent, will win at any show you take it to, I have a video of it running and a walk around video, and 40 detailed pictures, clean California title in my name, currently registered till next year.
LAT options:
LAT 5 weld on under ride traction bars
LAT 73 Headers with cut out plates you can unbolt for the track
LAT Hood
