Shelby wheels
I got my Shelby wheels from Branda, I don't know if there's more than one manufacturer. A word to the wise.... the Shelby rims, at least the ones I got, are VERY thick castings, which leaves the room inside the rim for brake clearance much smaller than one would expect with a 15" rim. I had to make my own caliper mounting brackets and brake hats (photo shows temporary spacers while I was figuring out exactly how deep the hats needed to be) to space the calipers and rotors much farther inboard than the standard mounting for the Wilwood brakes so they wouldn't rub on the rim. I also used smaller rotors on the front than Dale supplies, the same diameter as the back. So, it has the same brakes on all four wheels. The front rotor needed to be so far inboard it almost rubs on the steering ball joint (first attempt DID rub), and the rears are spaced in about as far as they can be without the caliper or e-brake assembly hitting the frame. If the rear axle didn't have a Panhard Rod they would probably knock on the frame in hard cornering. Anyway, it was TON of work and I'm not sure I'd recommend the same path to anyone.
I'm not sure what the legality/roadability would be if one were to turn down some of the metal on the inside of the rim. I mean, does the center rim really need to be an inch thick? All it's doing is holding the inner rim on. It seems 1/4" thick would be plenty good enough, the spun aluminum rims are even thinner than that. If one were to turn down (turn out may be more correct)the inner part of the rims so that the metal was 1/4" thick throughout, it would leave a lot more room inside for the brakes and maybe eliminate the need for so much brake modification.
However, with stock brakes it probably wouldn't be a problem.
Bob K.
B9471705
