Carbuilder
I'm hoping this will be a useful place to talk about adding A/C. This is not to tell me why I shouldn't do it and/or why it won't work. This is for those that have maybe considered it, and could add to what I currently know.
Let me also add that my car is modified; 347ci engine, different tranny and rear end, different front suspension, different seats, etc. So keeping anything stock is not an issue. I also have a completely different wiring harness with the fuse box where the glove compartment would be, so I can't go into that area of the dash.
I've added a Vintage Air system to my Factory Five 818C (kit car) so know a little about it. I've also read many times how people have added other makes of A/C, not been happy with it, switched to Vintage Air, and it worked great. It could be that systems that are smaller are smaller for a reason....they don't work as well.
The various Vintage Air systems I've looked at are fairly small when installed in a "normal" car. The interior of the Tiger is pretty small and there isn't much room. Here are the 4 different systems I've considered.
1) The totally hidden type that mounts up inside the dash. This is what I put in my 818C. Even the smallest unit is likely too large to fit. The unit does have heat/defrost and A/C, so some of the existing stuff under the dash can be removed. I don't think it helps to remove the heater core, as that area is remote from the under-dash area and doesn't free up space where the A/C evaporator would mount. This evaporator is about 19" long, 7 1/2" deep (front to back), and 9" high.
2) The other popular system is what was used in a lot of older cars, especially those that had dealer installed A/C. This is the unit that mounts under the dash. They are available in A/C only, and A/C and heat; no defrost though. I mocked one of these up with a cardboard box and if mounted in the centre of the dash, it doesn't interfere (too much?) with the driver or passenger. But is still is pretty big and a bit of an eye-sore. But it would fit and probably be the easiest way to get A/C. Maybe taking out the current blower motor would allow it to fit up under the dash just a bit. This evaporator is about 16" long, 5 1/4" high, and 12" deep.
3) There is a trunk mounted system. Obviously this would fit well enough. But I don't think that blowing cold air from back there would do much without ducts to bring it forward. Don't really see a good way to do that.
4) There is a vertical stack type unit. It fits under the dash, but extends down to the centre console. This would require the existing blower motor to be removed, probably along with the vents and some of the defrost ducting. Hard to mock this one up without actually removing things, but I'll do a better job of measuring and see what it looks like. This one has heat/defrost and A/C, so anything related to that with the factory stuff can be removed. This evaporator is about 16" long, 9" deep, and 12" high.
What I've found when searching is reference to someone that installed it and the very fuzzy pictures looked like it was under the dash. There was a Tiger for sale recently that apparently had A/C and it was not visible so must have been up under the dash. It would be nice to get some details from any one that has done it and could add some useful info.
This will be a winter project (what better time to add A/C?) so not something I'm jumping into right now.
What it looks like up under there with now:
