B
big_mike_85614
Guest
I am using a rebuild kit to refurbish my Girling MK2A brake booster. Outside the main piston there is a spacer, a rubber seal, and then another triangular sort of spacer. They just seem to push in. When I test work the plunger in and out the drag on the shaft just pulls out the rubber seal and the triangular spacer and they end up hanging on the shaft. How do you get these things to stay in place?
